Has anyone installed a power step on their bronco raptor? that fits?
Baldguy01
SCHWENKSVILLE
Looking for some options for my 24 Braptor. With out having to do a lot of carving of the body or moldings. Maybe there's no choice but to? Don't know. I appreciate any pictures and or feed back from those have gone down this path. I watched a vid on Elite's power step and was half the $ than the Amp. QUestion becomes if they work on our raptors or not.....thanks for looking!!!
KRB
Oregon
I am hooked on Rock Slide Engineering steps. They offer a little more protection and have worked great for me. Not much trimming required to make them fit with stock mudflaps.
Baldguy01
SCHWENKSVILLE
looks great! thanks for the reply! are you running a "lift" or perch collars? curious if I'd want to run a 39 bfg, would fit with
KRB
Oregon
I run Eibach Springs on the front which lifts it 1". Basically levels it. I run Nitto Ridge Grapplers 37X17x13.5 wheels are 17X9 +20mm (no rubbing).
scrufy
So Cal
Just have to say it.., yeah, I'm gonna be "that guy" thus time.
Lifting your Braptor with collars or springs actually disables it by limiting the droop. So your wheels don't touch the ground where they would before.
A Stock truck with 37s would probably get farther than your lifted track on 39s.
As for the step, if your doing anything hard-core, we like to use the sliders for just that. Sliding over boulders lije the soup bowl on the Rubicon.
The electric ones will probably bend up into a nice wave after a single run.
Just warning because if you bought a Raptor, you should be using it for mire than simple trails.
