2022+ Bronco Raptor Full-Width Front Lighting Upgrade
Burbank, CA
2022+ Bronco Raptor - Full 64" PRO Bumper Lighting Setup
This setup combines a 40" curved PRO light bar with two 12" PRO extensions for a wider lighting setup across the front bumper. The bars sit close to the bumper for an integrated look, and the kit bolts on using factory openings and hardware, with no cutting or drilling required.
Choose a white or yellow main beam for the center bar; the two extensions use white main lighting. All three bars feature amber DRL backlighting. The kit fits 2022–2026 Ford Bronco Raptor models and includes the wiring harness and mounting hardware.
Feel free to ask any questions!
Installation Guide:
For more information:
2021-Ford-Bronco-Raptor-XL-LED-Light-Bar-Kit-Bumper-Mount-Dual-Color-White-White-DL-High-Outpu...jpg
mandrautomotive
Burbank, CA
For those running the Bronco Raptor, would you go with the full 64" setup across the bumper or stick with just the center 40" bar? The side extensions fill out the front end while adding more lighting across the width of the bumper.
Curious to hear.
Light Output for the 40in Light Bar PRO, excluding the (2) 12" light bars :
mandrautomotive
Burbank, CA
Here's the full-width setup with the amber DRL on a Bronco Raptor. The kit is in stock and ships free anywhere in the continental U.S., and like all of our light kits it comes with a lifetime warranty. If you'd rather have a shop install it, here's our trusted installer list: https://mandronline.com/pages/trusted-installers
mandrautomotive
Burbank, CA
Here's the full 64" setup on a white Bronco Raptor. It's a 40" curved PRO bar in the middle with two 12" extension bars, all sitting slim on top of the bumper for a built-in look across the whole front end.
The PRO bars use a combo pattern that blends spot and driving optics for distance and width, and the kit bolts on using the factory openings and hardware with no cutting or drilling. Fits the 2022-2026 Bronco Raptor.
mandrautomotive
Burbank, CA
Another look at the full-width setup for the Bronco Raptor: a 40" curved PRO bar in the middle plus two 12" extension bars, all sitting slim on top of the bumper.
It's an easy install right on top of the bumper, and it's a complete bolt-on that uses the factory openings and hardware, with no cutting or drilling. The PRO bars use a combo pattern that blends spot and driving optics, with a white or yellow main beam and an amber DRL backglow. Fits 2022-2026 Ford Bronco Raptor.
Forum members get 10% off with code BroncoRaptorForum at checkout.
2022+ Ford Bronco Raptor XL
